Well, thanks dfergie for the reply.  Your answers led to me picking up a 5504 today.  I then spent more than two hours and didn't get very far.  Some of the terminology doesn't mean much to me, and it is likely that there are some steps missing in the original instructions that seem obvious to some folks but not to me.
With my schedule I won't have another chance to try again until Thursday, but I don't know what more I can do without help.  If someone can help me figure out what I am doing wrong then I will give it another go.
I apologize in advance for the length of this post!
I started by following instructions.  I installed .Net 1.1 (via Windows update -- anything else I have to do on this?), the WiRNS files, and Sqlite (from
www.sqlite.org).  I set up an account at labs.zap2it.com and selected my local channels and Voom channels.
Then I connected the ReplayTV box to my Voom box (via both composite and Svideo), and the ReplayTV box to my TV.  I intend to send the locals through composite and the Satellite channels through Svideo.
I turned on the ReplayTV and it insisted on going through an initial installation procedure (inputting zip code, phone number, etc.)  I tried going through all the steps, at first connecting via phone line.  It took about five minutes to download information.  Of course Voom didn't show up as a valid choice as a satellite system, presumably that won't change until after I use WiRNS correctly.  I don't have an actual network connection near the TV, so I was planning on doing all the WiRNS setup using a WiFi connected laptop and then later telling the Replay to go back to using the modem.
I tried manually setting IP information on the ReplayTV box under the Ethernet settings (DNS, etc.) but the ReplayTV unit didn't seem to have network access through the laptop.  I don't know much about computer networking (setting up our home WiFi network is as far as I got), so it is likely that there are some major steps I've missed here.  Do I have to do something to "share" the WiFi connection from the laptop?  Will this not work under WiFi at all?
I temporarily disabled the Windows Firewall as I understand that it might cause problems.  The laptop is connected to the internet via a WiFi connection, the Ethernet port on the ReplayTV is connected to the Ethernet port on the notebook.
Anyway... I started up WiRNS, and it seemed to load correctly.  It said that it was "starting configuration server on 127.0.0.1:8923", then "Plugin: ServerManagment.dll (1.0.1549.1264) loaded," and finally "Replay Network Server Emulation started."
I loaded a web browser, but nothing seems to be at 127.0.0.1:8923 or at localhost:8923.  I can't get to the web-based control panel for WiRNS, from which all other settings are adjusted.
So what now?
I don't think muddling through is going to work!  If anyone can spot some obvious things that I've missed then please let me know!  I'm willing to put a few more hours into this, but no more than that.  If I can't get it working by this weekend I'm going to return the unit for a refund.
Thanks in advance,
CDH.
