VOOM and OTA HDTV
sraider
I have the VOOM receivers and the powered antenna that I received from VOOM. I am receiving signals from the stations but receivers will not present programming in HDTV. I can get the shrunken version when I use the lesser quality video outputs from the receiver.
The signal strenghts are well into the green 95+. Any help or explanation would be helpful
1) Are you using an HD TV?
2) Are you connected to the HD output of the VOOM receiver?
sraider said:
yes to both
Disconnect the low-res cable from the TV. Just leave the DVI or component (YPrPb) cables. Cycle through your TV video inputs with the TV remote.
Voom Ota Better Than Dish 811
OTA HDTV Tuner integration
