Asked this question over at AVSForum and best anyone could come up with was dying HDD. One of them sent me this way figuring if you guys didn't know, no one would.
My equipment:
ViP 722, Antennacraft HBU22 antenna, Winegard HDP269 pre-amp. Satellite and OTA signals are coming into the house via one diplexed RG6 coax line.
Anyway, I can directly view the channel just fine. Never had a drop out, blocking or pixellation due to bad signal. However, the DVR struggles with any DVR related activity ONLY on this one channel. Recordings from timer, manual recordings, rewind, fast forward, etc., etc. Trying to do any of this causes horrific blocking, audio dropouts and in the case of DVR recordings, the recorded event will cease playing back about two minutes into the recording. In acts almost exactly like there is a poor signal getting to the box. Signal strength according to the 722 is 81-85, the highest of any of the channels I pick up. I do not have the same trouble with any of the other OTA network broadcasts or any of the satellite broadcasts.
I originally thought it may be a HDD or bandwidth issue, but the local CBS affiliate is not giving me the same problem and has higher bandwidth, judging by consistently larger DVR file sizes of saved programs of similar length. I have reset the 722, unplugged it and received no errors on reboot.
Next I thought it may have been signal overload. I can receive channel 8 on from two different transmitters. One (channel 21) is only about 7 miles away and gives a slightly better signal. Thinking the pre-amp may be overloading the signal since I was so close, I deleted channel 8 via 21 and manually added it using the transmitter that is 40+ miles away (main channel 8). My signal strength dropped about ten points to 74-76, but the DVR results are the same.
The type of broadcast makes no difference, either; Saturday morning college football in HD, weekday afternoon Ellen in SD, late night Jimmy Kimmel in HD.... makes no difference.
I have had a couple of online chats with the Dish tech support and all they have come up with so far is that they can't guarantee the OTA performance with their DVR.
If anyone has any ideas, I'd love to hear it. Short of getting a new box from Dish, I don't know what else to do. Thanks.
My equipment:
