Hello all. I'm new to the forums here, what an amazing wealth of information!! I tried a forum search, and found a lot of info on this issue but most of it seemed pretty old and I can't determine the relevance now..eg firmware issues, etc.
The story:
I have a 722 running in single-mode. I had my first for a year with zero issues. Absolutely adored the box until one day, about a month ago it just started to reboot constantly. We're talking before it even gets to acquiring satellites.
The green light comes on for maybe five seconds and BAM, reboot. Ocassionally, it will come up and I'll get from 1 to 120 minutes of TV, though it hasn't in two days now.
So when the first one started doing this, I called Dish, went over some mundane troubleshooting which was clearly irrelevant. Still, I stuck with it, went through the steps and ultimately got what I requested in the first ten seconds - a replacement receiver.
The new receiver arrived quickly, I had some trouble activating it but all was well. Then, when prompted to reset the box by the tech, the reset button pushed right through the front of the case..nice job on the refurb eh? So they sent another refurb.
This one has pretty much never worked. I got it up and running, thought all was well but after a few days it started as the other. First it was well spaced out, then more frequently and now it just reboots non-stop. It's almost humorous in a depressing sort of way. So I called again, and now they are sending out a tech tomorrow.
Some facts about the setup:
While overheating may be an issue, this box is in the EXACT same location as the first one I had which lasted over a year with no such heat issues. I've even moved the components around so that the VCR is below it and the DVD player beside it, neither of which are frequently turned on. I do not believe it to be a heat issue. Besides, if I unplug it for 24 hours, it does the same thing when completely cold.
Power issues? I've tried plugging the box via an extension chord into an outlet across the room which is on an entirely different breaker. Dish said it was probably an issue with being underpowered, so this was my test. I don't think that is the problem. My powerstrip is a Monster Power Station (boo monster, I didn't know at the time of purchase) and NO other components have ANY issues.
System Status: When it's up, everything is nominal. The switch checks are all OK or Dual on both feeds, with all three satellites showing up. The broadband connection is working, everything seems fine.
I'm not at home, so I can't really answer any questions via the menu system, not that I can get there anyway ;-)
Any help or advice would be greatly appreciated. I'm at my wits end. I love Dish's programming and pricing, but simply can't continue to experience these sorts of problems.
Info of possible relavance:
HDMI, Optical, No Offair Antenna
The story:
