I've just installed a Viewsat VS2000 with a 33" Fortec Dish on a HH90 Motor by STAB.  I am seeing 62 channels on both IntelSat5 & Nimiq 1,2, but all the Channels are under the "Scrambled" Category, which cannot be seen.  Under the FTA selection, it says No Channels...
BTW Iceberg... Low & High LNB value of 10600 does not work. 10750 worked, and when you had mentioned something about setting 22K value to be set to "ON", that option only comes up, if you have a "Standard" LNB. Since I have a "Universal" LNB, the 22K option goes away, and it asks for Low LNB instead. So I hope 10750 for both Low & High are correct.
Also... I still don't understand how the Disecq Option works. Everytime I set the "Motor" Option to either User or Installer, it moves the dish immediately almost all the way to the West. It doesn't matter which Satellite I choose, it always goes all the way to the West. If I leave it on "Off" however, the dish will not spin at all. So if I am pointed towards a satellite, then I will be able to get a good 70+ signal.
So if I accidentally left the Motor Option on either "User" or "Installer", I would have to manually spin the Dish step by step in the User Mode to get the dish pointing towards the correct Longitude again... Very frustrating...
Please Help before I totally give up on this FTA venture of almost 1 week.
Thanks.
Thanks.
