hi there im unable to receive any vertical polarized transponders .horizontals come in good.im on intelesat 5 at 97 degrees west i used to be able to get them thanks ku band
Welcome to SatelliteGuys!
Tell us what equipment brand and models you are using. Receiver, LNBF, motorized, switches, etc.
Did it previously work or is this a new install?
Are you trying to receive C-band or KU-LNBF? What size dish? LNBF? LNBF LO 5150 setting would be used for C-band. KU-LNBFs use either 10750 or 9750/10600 depending on the type of LNBF.
Example of channels being received? Examples of missing channels?
Is the LNBF voltage menu set on AUTO or 13/18?
The LNBF or the receiver may be defective. To test for correct receiver polarity switching voltage use a voltage tester on the coax cable (13Vdc on a vertical transponder and 18Vdc on horizontal). If the receiver voltage is correct, then the LNBF may be defective.
i have used this lnb before and it worked on 10750 but now it gets more stations on 5150 .i dont find a voltage setup in menue it remains at 18voltsim using a 3 foot dish with a inexpensive lnb.im trying to use it for ku band but noticed it received more transponders when i set it on 5150 rather than 10750 .this problem started after i had stored the receiver awhile cause i had installed a Dish brand receiver on same pole.when i reinstalled it after a couple years i had to have it on 5150.i checked the switching voltage under load and it stays on 18 volts
