cool...thanks for the info
I've seen the Skyvision place a couple years ago (they're about 3 hours from my house)
I've seen the Skyvision place a couple years ago (they're about 3 hours from my house)![]()
Well the 905 arrived today. Hooked it up and it powered up
(the guy I got it from said he didnt know if it worked because it powered up then off right away....that's the old Motorola reset thing)
I tuned to X4 (and had to change the LNB in the menu to 90 degree rotated) and it worked. Have audio channels
Tried to go to AMC3 KU (I guess thats called K3?) and there are no channels logged on that satellite in the unit...stays on channel 0...so the maps are realy outdated
I did tune to AMC5 (k5) and did get OETA
So here are my questions....
Once I get the big dish moved out front probably this weekend and aimed at say G0 (where Showtime is) or G1 (where the guide is), I do a master reset which I know clears everything (thats why I havent done it yet)...then what? Leave the unit off for 1/2 hour or so?
Will it load all the channels (even the ones that are not subscribed) or just what is subscribed?
I know I'll have more questions but I want to take it one step at a time
Added your last post to the C-Band FAQ's, thanks tvropro!![]()
nope. When you change satellites it gives you a message that says to turn the analog box to the same satellite. I just hit "exit" and it shows the new satellite. If I slaved it to an analog, I would hit the "go to analog" then the analog box would be live.It sounds like the 905 is kind of nice slaved to a DVB box. I was wondering if you were going to get any complaints about the positioner. I wasn't sure if the 905 had any tie-in to the motor control on the analog box it's usually slaved to.
what about the channel maps? It is seriously outdated...no channels on K3, 95% of the X4 channels are missing, no Nebraska PBS on T5 (old satellite) or T6 (where it moved to)I wouldn't think you need a master reset but I guess it can't hurt. That's usually only needed when the unit runs out of memory.
The 905 / 920 I think just need a power cycle to pull down new maps. You can watch the trip count on the diagnostics screen increment to see if you're receiving hits. I think it's options, 6-0-5 to get there. This is from memory and may be completely different on the 905.
I found that out right awayThe menus are the same as Starchoice so you will be very familiar with them and the guide.
I can get K5-600 but K3-640 doesn't show up...no channels are on K3...so it needs the downaloads.T6/600 - 618 is Nebraska PBS ITC, simulcasted on T5-600-618 as well, K3-640,
k5-600, T7 (121 cband side)-799-804 has some ITC stuff.
good to knowAnything that is lettered G will be X on Ku, ex. G0-X0, G3-X3
T's will be L's, T6=L6, W's are K's....W4=K4, If you can get over to P9 there is some good music on that one as well.
yep. right now I have it on KU LNBF 90 degrees rotated and K5 & X4 are working fineBe sure in your menu, you have selcted both C/Ku LNB's as well so your Ku satellite tiles will show up.
yes they help greatlyHope these little hints help, not sure if it is like the 922 but this is how you do it on the 922.
Just wanted to add one more note, G1-3 is tricky to pull in, but once that DCII light comes on, that means you have a lock...I would suggest getting an alacarte subscription just for some of the FTA stuff that wont come in unless the box has a subscription. That's where the generics come into play and then there is a whole other situation to talk about, but once you figured them out, its easy.
I know on the 922 to add channels all I have to do is go to G1-3 and take a rehit. But if he's missing a bunch of stuff a master reset is probably better. If he subscribes to something ALTV, & Blackbelt will turn on also. There in U mode. If it's FP I think you don't need a sub but for U you need a subcription. I would get the big dish set up on G1-3 do the maps then worry about sub's. If ICE's 6 foot was alot bigger I'd say leave it there and sub to the HBO/MAX master's. Im watching them right now BEST DIGITAL VIDEO OUT THERE!![]()
The 905 should be like the 922, so you should be able to go to G0-5 wait about 3-5 minutes and all should be ok, as long as you have the DC lock, the 920 is the only one that needs the unplug replug everytime the maps are updated.
A MR is up to you, the 905 should be good to go after you load the new maps.
I would not go to G1-3 unless you want the guide for one day![]()
So you're saying I dont even need to do a MR...just go to G0-5 as an example and let it sit for 5 minutes? Do I leave the unit on or off or does it matter?
