Much of this has been covered in other threads so my apologies in advance for redundancies. I have a primary home with DirecTV subscription and the following equipment:
Slimline SWM SL35 4NR5-01 (one line)
Genie Gen 3 / DVR HR44-500
Genie Mini x 3 C51-700
RG-6 Cable from Dish
My objective is set up a dish at a vacation home I use sparingly (2-4 weeks per year) in Northern MI. I understand this to be technically against the terms of use but OK as long as both sites are not watching simultaneously (which in my case will never happen). I can bring my Genie or Mini with me when I travel to the vacation home. I AM A ROOKIE AT THIS STUFF SO ASSUME I KNOW NOTHING....
The vacation home has trees across the front blocking the South, therefore I plan to mount the LNB dish on a pole approximately 65' from the house and about 100ft from where the TV is. Question 1: any issues here? Should I use RG-11 or other tech to ensure good signal quality? Question 2: I plan to buy an exact duplicate LNB Dish (from eBay or whatever) - good idea? Any tips on pole / mounting, etc? Should the buried coax be in a conduit?
I read about powering the LNB. Question 3: what do I need to make this happen?
I'm planning to hook up to a single television. Question 4: I'm assuming I don't need a splitter of any kind. Correct?
I'm planning to bring my Genie Gen 3 / DVR along with power cables, remotes, etc. Question 5: good move? Will the Mini suffice?
Question 6: If I do so, should I expect to have the same channel package that I have at my primary home? Does this include local channels?
Question 7: I have some neighbors with DirecTV so I can get the general direction of the LNB Dish. Should I get other equipment, etc to ensure this is done correctly? Or, will the set up guide the signal strength for me?
Question 8: This is the biggie - what am I missing?
Very appreciative of the advice, etc.
