(V) and (H) Channels on 4dtv
chefwan
752
South Carolina
here's an update...what do you guys think cause's this. i was messing with settings on a (V) channel and i was in dish settings and changed it to rotated 90 degree's undre feedhorn polarization and Vertical worked great all of them without any skips . so i go out and change it to a (H) channel and it skips like the (V) did before i changed it from rotated 90 i have to use standard on (H) channels and Rotated 90 for (V) what cause's this? i figured out why it does it they work but i have to change back and forth in the menu for (H) and (v) to work clear without any skips. what could cause this if anyone knows please do let me know thanks.on the DSR-922 4dtv
What do you mean by skips?
Did you change the servo, maybe it was not done right?
With a feedhorn you should use standard and not rotate 90, do you have another feeds to test out? maybe the probe is having problems turning, I never heard of this one that why I ain't said nothing :)
Your skew settings could be way off, so you will most probably need to postion the feed in a way till everything is working right, make sure your V and H are ok, one will be + and one will be - they should be 90 apart.
Good Luck!
and how do i adjust the skew setting. ill look today and see if the probe is turning. thanks
Well you mite need to go outside and spin the feed, if you have a adjustable ring it will be easy, your skew is in the menu, same menu you use to bump the dish, if you don't see skew then you are not set for c/ku lnb's so that will need to be done.
Did you do a master reset on the 4dtv? if not it would be good to do to get y6our settings good.
This website has very kindly made available the DSR-922 manual in the FTA manuals area. Pages 71 and 72 of the manual show how to skew and other fine tuning adjustments.
hey as a matter of fact i think cheffwan said he switched it back to lnbf's because it stabilized the picture. Right Cheffwan? Didn't you take it off the lnb setting?
VIdeoCipher II model VC2100E
Anyone remember this?
