Using satellite dish mount for OTA antenna
Txkiwi
Garland, tx
I have this great antenna that I had in my attic. Unfortunately some channels were spotty, I decided to move it outside. I have a Dish Antenna mounted to the side of my house, and they did such a good job I want to keep the mounting and use it for my antenna. So I removed the dish and kept the mount.
The problem? Height, the antenna is so big it's hitting the roof. I need height. Anyone know of a mast that will fit into the Dish's mount?
It will probably take some jury rigging but many different size pipes will fit inside the mount. The DISH mount is 1 5/8" outside diameter so you can put a smaller pipe inside and bolt it together or a larger size on the outside then bolt it together. You might find a muffler shop to swedge a pipe to fit the mast. How large a diameter will your TV antenna clamp on to?
Channel Master Announces Replenished Inventory of Popular DVR+ Product
Where to put modulators?
