using 2 dishes to get signal
jjcontreras
Los Angeles
any way this can be accomplished? curently running slimline 3 lnb but want to get signal from 110 and 119 on another dish? its an hd receiver by the way
You can do it... you just have to figure out what connectors on the LNB are for which satellite... and take the 2 lines from the other dish and connect them to a multi dish switch! WARNING if you are using a E* dish for 110 and 119 it more than likely will not work... I only got a single LNB from a E* dish to work in this manner...
When I had E* I had 4x4 foor dishes for each satellite 121, 119, 110, and i think 65.9... its been about 8 years since i have done that setup lol
It would be easier to get a 5 LNB set up.
Put the 5 lnb on and re run your coax, make sure to change your setting and run the RESET Sat set up.
Install question (new customer)
if you came from dish
