Does anyone know if the E* HD add on will allow partitioned drives.  I heard some rumor that it was limited to 750G  I have a 1 TB drive and was trying to decide how it should be configured if the 1TB is too large.
Re the stupid comment about being a beta tester. I don't believe you knew what you meant until LER gave you an explanation to fall back on. If you can't explain something you put an emoticon on it and let others guess what you're saying. After that you select one that makes sense to you. But originally, all you tried to do was be a sour puss about this offering. I'd be surprised if you aren't a shill for D*. Am I picking on you. YES I am. But shills and bad mouthers are beginning to annoy me to great boredom.
Preparing to be a better cranky geek in my old age. Maybe Divorak will invite me on his show
So.... can you connect the USB hard drive to the front port as well?
Considering that the drive is limited to archival purposes
This is correct you can play video direct off the external hard drive (plus have complte trick play functions) just like it was playing off your internal hard drive.I believe on the demo video it showed that you copy your videos from the 622 to the external USB HD, but you could then playback your archived videos directly from the external drive without having to copy them back to the 622
 It'll arrive probably by the 7th and then I'll be eagerly awaiting the 15th.
I have 2 vip 622s. Can I record on the external hardrive on one 622 and hook it up to my other 622 and view it??
Don, give me a break man! I'm actually a software developer and a E* customer! Good god man, I was only giving LER a thumbs up b/c he knew what I meant!! And if you must know, I was referring to reports here that some people experienced E* actually rolling back the previous software update. Dude, chill out! I figured more people would pick up on my sarcasm but instead I must have offended some, lighten up! I've been waiting for the external support too, i just hope it works right and E* reserved some QA time before they release it.
