You don't actually need a kit or any special part to control TV 1 with a UHF remote. You can use the "TV2" UHF remotes that are available on eBay and everywhere else. You can even use the TV2 remote that came with your 522. It will work great. The only problem (if you want to call it that) is that the UHF remote that will be controlling TV1 will say "TV2" on the bottom (you know, the little blue part). As long as you don't mind the remote saying TV2, go ahead and order one from eBay or anywhere else you like. Then follow this procedure:
NOTE: This will also work with the 322 model. The same basic procedure, except that a couple of menu numbers are different on the 322 from the following instructions. You should still be able to figure it out though.
NOTE: When purchasing a remote from eBay, be certain to get a "UHF Pro" remote. The older Dish UHF remotes (model #501, 508, 510, etc.) will
NOT work. Make sure you get a "UHF Pro" remote
exactly like the TV2 one that comes with the 522 (or 322 if that applies to you). Don't get scammed!
NOTE: Steps 1 through 7 to be completed with your current TV1 (IR/Infrared) remote.
Go to the room where the 522 is, turn on the TV and TV1 tuner and, using your current TV1 (IR) remote, enter the following in order:
1. "Menu"
2. "System Setup" (#6)
3. "Installation" (#1)
4. "TV1 UHF Pro Setup" (#6)
5. Now go to the left side of the screen, highlight "Enable," and hit "Select" on your remote.
6. Now go back to the right ("System Info" should be highlighted) and hit "Select" on your remote.
You should now be looking at the "System Info" screen.
7. Press the "Up" button on your remote twice until the box next to "Primary Remote Address" is highlighted in yellow.
Now, grab your "TV2" UHF (blue bottom) remote and follow this procedure:
NOTE: All steps from here on will use the TV2 (UHF) remote.
1. Hold down the "Sat" button (upper left corner of the remote) for a few seconds until all four of the top buttons light up. When they all light up, release the "Sat" button.
The Sat button should now be flashing.
2. Enter a number on the keypad of the remote. In can be any number between 1 and 16 but it MUST be different than the number that's in the lower box (next to "Secondary Remote Address"). If you do try to enter the same number, you will be prompted that it isn't allowed. (NOTE: If you also have a 322 in your home, please see my message below for 322 owners.)
3. After entering your number, press the pound/search key "#" (lower right corner). Wait a second. The "Sat" button (upper left corner) should flash three times.
4. After the Sat button has finished flashing, press the "Record" button on the remote (near the middle, under the "Pause" button). The yellow box should now display the number you entered in step #2.
5. Press the "Down" button on the remote two times until "Done" is highlighted.
6. Press "Select" on the remote.
You are now controlling TV1 of your 522 with a UHF remote. Enjoy!
For those that also have a 322 in their home, before entering a number 1 through 16 (from step #2, above) please go to the "System Info" screen on your 322 and note the "Secondary Remote Address" number. Make sure that when you pick a number in step #2 that it is different than the "Secondary Remote Address" from your 322. You do
NOT want two different TVs in your home to be using UHF remotes with the same address (1 through 16 number). You have to make sure to check the system info screens and confirm that all remotes operating on UHF are set with different addresses. You can even have all four TVs (two from a 522 and two from a 322) operating with UHF remotes, but in that scenario each remote would have to be assigned a different address number.
