Up conversion is not a setting. If you have a uhdtv the set will up convert to uhd. Still, the tv can only do so much. Bad source = bad picture. No matter the quality of the tv.
Not quite bud, the 4K VOD content available right now downloads for the satellite NOT internet. The movies and promos are put in a rotation cycle and when one is available and requested by the customer it downloads. Also having Genie Recommends turned on means that DIRECTV will have two fresh copies available at any time on the customers DVR (Genie) of 4K contentYup. Just remember all the 4K content on DIRECTV today is VOD content that gets downloaded off the internet.
I would think D* would not lease a 61 if you didn't already have a genie to work it ....
The same reason why SD looks like crap on todays HDTV's. Your TV have more pixels than the info is getting, thus it has to interpolate the missing missing ones. Some TVs do a great job at up-scaling, others do a piss poor job.Anyone fill me in on why the picture isn't much better than my previous Vizio 48' HDTV?
l
Visio currently does not support RVU. As of this writing only Samsung, Sony, & LG sports RVUScott; thanks for the help and advice,
What if any "upgrades" do I need to make to take advantage of the UHD tv picture quality from my existing equipment with DirecTv service?
Should I buy a C64K tuner and have it activated to better my picture quality or wait?
How can I verify my NEW Vizio 55' UHD tv supports the DirecTv RVU, (what's RVU mean) to be sure it was worth getting this new set?
Cheers
nigel
Without a Genie, a C61K is just paper wight. Also don't expect the C61K to make any non-4K picture any better than you have now. The C61K only up-converts 1080p to 4K, but then again there is no linear TV on 1080p either. Only VODScott;
Just ordered a C61K from your link.
Got two day delivery.
When it gets here should I just install it like any other and then call DirecTv, (I have the technician contact number at DirecTv) and have the existing one closed and the new one activated?
Cheers
nigel
All the 'C' models have NO TUNER.Several responses;
Voyager6; I don't know what you mean by "upconversion". I didn't see any thing referring to that while doing the initial setup.
Jimbo; I have HDMI cables for my all connections if that's what you mean.
Zashel; You're right, I don't have Genie. Is that something I need to look into? Don't know what it is.
ejb1980; Scott recommended the C61K as the newest tuner so that's why I ordered one.
I'm hoping / assuming the C61K is a tuner that I feed the sat feed cable into and HDMI cable out to the tv after activation?
Thanks for all your help and patience.
Cheers
nigel
So does he get billed after a certain amount of time if it's not activated ?If you look back, he didn't get it thru D*, he ordered it on his own from Solid Signal (because he knows ALL about these since he's done D* since day 1, you know...even though he doesn't even know what a Genie is... )
Solid Signal probably assumes that if you're smart enough to be ordering this stuff on your own, you know how it all works...& they probably will NOT allow him to return it, either. Oh well, good $99 lesson for him to learn...
I hope to god this ISN'T one of D*'s current techs they send out...I've been dealing with DirecTv systems since they first came out.
I had a customer about 2 years ago, "as you can tell im really into electronics" dude had an old tube tv with like 5 vcrs hooked together. Dbag
So, are you going to try and return the recvr you currently have, it doesn't work without a Genie to power it.I'm sorry I don't meet "dishrich's" intellectual standards, every forum has at least one a$$hole that looks for things to pick out rather than be helpful, but I said, "I've been dealing DirecTv since they first came out" not that I knew everything, so as usual, with these people, they are usually wrong, so I and most tend to ignore them and I will.
texasbrit, again thanks for the help, you and Scott, (and others) have been a great help. When I get the numbers from the shop tuner i'll get back with better informed queries.
I was hoping for 4K quality and I should have done my homework before I bought the new tv but I did need another tv so I thought I'd go for it while I was at it.
Had I done my homework I wouldn't have bought Vizio. Just have had great service from my existing 48" Vizio.
Solid Signal, as well have been a great help with other bits and with a little more help i'm sure i'll have the best available DirecTv experience with what I have to work with.
Cheers
nigel
