under apps sports mosaic(college sports multiview) includes sec network-pac12 network-big10 network-espnu-lhn(longhorn network)-espn news.
yeah - after updating and by the time my TV lit up I was on "live" TV - that should make a lot of people happy!I got u307 this morning seen a change,when you first turn on the h3 the home page comes up now it turns itself off after a few seconds.
hmm.... I already had a "Sports Mosaic" (College Sports Multi-view) before the update - same as what you describe. I couldn't change anything though - maybe this is different? I thought that what we've been waiting for is supposed to be called "Sports Bar"? Is there something needed to activate maybe?under apps sports mosaic(college sports multiview) includes sec network-pac12 network-big10 network-espnu-lhn(longhorn network)-espn news.
Yes - and you can still create a 6th folder (or more) which will be wiped out at next re-start. Still, going all the way to U307 I have to believe that a lot of "bugs" were fixed....Folder issue still not fixed. Still shows that you have recorded shows when there is none in the folder.
Also format issue is still not fixed.
Still no Netflix on 4K Joey.
Sent from my iPhone using SatelliteGuys mobile app
Sometimes (though not always) a simple reboot has fixed this for me. I'll have to try your suggestion next time that doesn't work.On the folder problem, I have found that when I move everything out of the folder then delete it (the folder), then recreate it and move the recordings back into it, the count problem is fixed. For me anyway. **Important!! You have to go back to each timer that is sending recordings to that folder and re-select the folder, otherwise, it will send those recordings into oblivion and oblivion is a cold, dark place. Must be some internal folder id that must be re-linked or something.
That is a software issue, no need to contact DISH. It is something they are working on now that Multiview has been released.
Let's hope that issue is corrected shortly.![]()
I had to power down for mine to start, but I have stand by turned off.The new firmware is an automatic download correct?
Sent from my iPad using SatelliteGuys mobile app
