Two Hopper 3 with 10 Joeys
hedgesjd
Ohio
I have installed two Hopper3s with a total of 10 Joeys (5 on each hopper). I utilized a hybrid LNB and Western Arc with hybrid solo hub and 4 port splitters. At first I thought I could utilize the Dish Hybrid Duo Hub 203961 and one DISH. It kept telling me that the 2nd Hopper3 was connected to the wrong port. I had to install a second Dish and utilize two Hybrid Solo Hub 203952, one for each hopper(dish) and two 4 port splitters to get the joeys to work. This worked fine...I'm actually wondering what the DISH Hybrid Duo Hub is for? Could I've utilized a single Hybrid duo hub in place of using two hybrid solo hubs?
You CAN have two Hopper 3's on a single dish, but you have to use a DPP LNB (or 3 DP single LNB's) running into a DPH42 switch; the Hybrid LNB was never made to support more than a single Hopper 3.
Here's a sample diagram on the correct way: (you can put splitters on the client outputs of the hubs for more joey's)
No, those are for using two Hoppers or HWS's on a single hybrid LNB, which you CAN do, since they only have 3 tuners each.
OK, I'll bite. Why do you need so many dvrs and joeys? Are you running a hotel? I don't have that much I would record and when I had the Hopper 3 with DISH, I never used all 16 tuners at the same time except to test that it could record 16 things at the same time.
It's not really about the dvr space or the tuners. He obviously has 12 tvs (so the question of why so many tvs still stands lol), but one hopper3 despite having 16 tuners only supports 6 joeys, so if you have more than 7 tvs you need a second hopper3.
Backup comes to mind if one h3 goes down and or break the 2nd can take over till it be fixed/replaced, that why I have a 2 h3 system, And why I had 2 hws system prior, was never about tunners, and i know others have do same for similar reasons.
I was almost yearly replace there solo DVR , which wasnt issue cause that only effect one tv at time, now it would be all when one dvr box to rule them all
Speaking about hotels, do they have a different setup because I remember when I visit hotels, the channels are usually changed directly using the tv remote and doesn't have a set top box of any kind.
Setups like that would usually be a complex setup consisting of 10-32 211s or wallys. Each receiver is tuned to one specific channel and then the output is sent to an rf modulator (each on a different rf channel) and then to a series of splitters that combine all the inputs from all the receivers then output it to all the rooms. Then you just run a channel scan on each tv. This method results in a standard definition picture and also because of high db loss in the system the picture is often fuzzy. And this is why despite being on satellite there's only a handful of channels available. They just put the most popular ones on plus the locals.
Makes sense. Thanks!
DISH Announces New TV Bundle
110/119 Listings Post 129 Transition (Updated 7/1/2024)
