TV2 woes
Lemmiwinks
I have a 522 receiver in my living room and just hooked up a sansui 20" tv in the bedroom. For the life of me, I can't get remote 2 to work, other than controlling volume & tv channels - but not the receiver. I've done the power scans, tried many codes, tried 2 different remotes - nothing works. The remote for Tv 1 is a 5.0, the tv2 is a 6.0. This one didn't work so Dish sent me another one for TV2 - this time a 6.3. Still can't see the receiver from TV 2, and it's only about 10' away!
Both Tvs are set to Air (Tv1, 3 - Tv2, 60), system is unlocked, both remote address are set to 1, all cables are in the right place.
The only way I can watch a channel in the bedroom is to set it on single mode and turn on the channel I want to watch on TV1. Why can't I get either freakin' remotes to work with the receiver!!
"both remote address are set to 1"
Change the TV2 remote to something else. Go to TV1 and press Menu, 6, 1, 3 you'll get the Sys Info screen. Using the TV2 remote:
- Press and hold the SAT button (about six seconds) until all mode button backlights come on, then release.
- Use the number buttons to enter a number from 1 to 15. The light will blink off after each digit is entered and then return to a steady light.
- Press the POUND (#) button. If the code entered is valid for the remote, the SAT mode light flashes three times.
- Press the Record button. The number in the Remote Address field should match the one you input.
- To verify the code, press and hold the SAT mode button until the mode lights come on. Then press the POUND (#) button twice. The light will flash the address.
Dish 322 and 3900 w/ dpp lnb problems
Charlie Accepts the Award
