TV input button on Remote?
rapidturtle
519
87
North Eastern PA
Is there anyway to get the input button to work with my T.V.? I have a Sharp flat screen and the remote controls the volume and such. I also set it up for AV1, and the menu button works, but not the T.V. input button. I can't navigate the menu though, as the up and down arrows seem to just change the channel, which brings it to the cable input.
Also, which recvr are you referring to ?
Thats important because the older recvrs had more complicated process to programming, the newer H/HR24's pretty much program themselves once you point it in the right direction.
Not sure what the HR34's do as I don't have one.
Typically, there are more than 1 code that will work for your set .... the first one you find may turn it on and off and volume, but not other things, try a different code !
Special Opportunity for SatelliteGuys members with Directv iPad app
HD DVR
