ok i searched this forum and can't seem to find a solution for this problem: (sorry if my terminology is off, i'm still a dish newb)
Current Equipment Setup:
1 dish pro plus and an lnb that says dpplus on it, on the back it says dishHD with two lnb plastic things, its has ports 1 2 3, a fourth port connected to an attached lnb with a metal arm.
1 Vip222k reciever
the cable runs from dish plug 1 to a triplexer in living room. we have the main tv and then two other tvs watch the same thing via dual tuner.
New Setup i'm trying to get going:
I'm adding a VIP612 dvr receiver.
MY problem, HOW TO WIRE THIS!?!?!?
I've read many conflicting things that i do/dont need a switch because a switch is supposedly built into the lnb??!? that i need to use separators? i'm losing my mind and i can't find any wiring diagram for this.
So if someone can give me a quick run through of if i need to use switches or splitters or not, and a quick description of how to wire, you will save my life!
My end outcome is i want to have the 222k in the living room working and having the dual tuner power the tv w/o receiver in spare room like now, and then the vip612dvr in bedroom that has dual tuner sat in's working to.
Thanks in advance, and sorry for my dish newbiness!
1 Vip222k reciever
