I see a possible problem? In one of the pictures at the link in the above post, looking at the home made mount, I don't see a place to adjust the declination. If that is the case, then you probably won't get the outter sats, or if you get the outter sats, you probably won't get the middle sats. With a polar mount set-up, you will need a way to adjust the declination to travel the arc correctly. From your location the declination would be around 4-5 degrees, probably closer to 5. It would point the top of the dish in a more downward position. You could possibly put some washers in the 2 top bolts that mount the dish to the mount and achieve this. Good Luck!
Maybe I'm missing something, while looking at the pictures? If so, hopefully I'm wrong and everything will track just fine?
Al
