True South Satellite for new location
Brabo
18
Columbus, Ohio
We recently moved and have an awesome southern exposure, but I'm a little confused about finding my true south satellite. One source (I think Iceberg or PSB) said use your longitude (82 degrees west/ Mount Gilead OH) which would be Nimiq 2 and another (Sadoun) said our true south is 192 degrees west on the compass. Our exact location is 40 degrees north and 82 degrees west.
Also, if I were to pick one satellite for FTA from this location, which would you suggest?
As always, thanks for your help.
Which satellite to pick for a "fixed" installation depends on your tastes. If you want network style programming aim at g10, if you want ethnic programming point at IA5, if you want PBS point at AMC3. It really depends on what you want to watch, there is a lot of stuff out there ;-)
Uh Oh...My true south
Iceberg said:
the true south satellite is the same as your longitude, which in your case is Nimiq2 (82W)
My true south is 119 (Reno's Longitude)! What should I aim at (getting back into install mode!) ?
Want no part of that action!:confused:
Jeff
Thanks again!
Iceberg said:
Dish 119 (Echo 7)
use transponder 2 as TP1 is a spotbeam so you may not be able to pick it up :)
Thanks again Iceberg....One great thing about procrastination, is that I get all kinds of questions out of the way!!! The big problem is that I can still see and hear really excellent FTA programs on my BUD, so it is not like someone has hit me with a cattle prod!
This is what happens when you forget that you have a new tool for installls....THE BIRDOG METER <MY NICEST =XMAS GIFT>!
Forgot, I can always load that SAT into my Birdog meter, and just zero in on it (it seems to really lock to a listed SAT...I mean within 1 click of the actuator arm of the BUD!)! Then install the Motor Sg100, Then Usals to the FTA birds....I Hope!
Nice thing is that there is a fallback always available (THE BUD) just in case I miss the first time, I will just rehook the receiver to the BUD...THAT WAY YOU DO NOT OBSCESS ABOUT WHAT YOU MAY HAVE DONE WRONG! Like formatting a disk with the old one backed up!:D
Regards
Jeff
I would use IA-8
Code:
North Riverside, IL 60546
Latitude 41° 50.244'N Longitude 87° 49.284'W
              Sat Name Sat Lng Az(t) Az(m)   El  Skew
 *** DBS SATELLITE ***
         EchoStar 3/R1   61.5W 143.4 146.7 34.8 -26.3
          EchoStar 6/8  110.0W 211.4 214.7 36.7  22.9
            EchoStar 7  119.0W 222.2 225.5 32.2  30.0
            EchoStar 5  129.0W 232.7 236.0 26.3  36.3
          EchoStar 1/2  148.0W 249.1 252.4 13.3  44.1
               Nimiq 2   82.0W 171.3 174.6 41.3  -6.5
             Nimiq 1/3   91.0W 184.8 188.0 41.6   3.5
       DirecTV 1R/4S/8  101.0W 199.3 202.6 39.8  14.3
             DirecTV 5  110.0W 211.4 214.7 36.7  22.9
            DirecTV 7S  119.0W 222.2 225.5 32.2  30.0
*** All Satellites 24W - 148W ***
          Intelsat 905   24.5W 108.5 111.8 11.0 -44.9
          Intelsat 907   27.5W 110.8 114.1 13.2 -44.1
         Hispasat 1C/D   30.0W 112.8 116.1 15.0 -43.4
          Intelsat 801   31.5W 114.0 117.3 16.0 -42.9
          Intelsat 903   34.5W 116.4 119.7 18.2 -41.9
           AMC 12/T 11   37.5W 119.0 122.2 20.2 -40.7
               NSS 806   40.5W 121.6 124.9 22.3 -39.4
             Pas 3R/6B   43.0W 123.9 127.2 24.0 -38.2
                Pas 1R   45.0W 125.7 129.0 25.3 -37.2
          Intelsat 705   50.0W 130.7 134.0 28.4 -34.4
          Intelsat 707   53.0W 133.8 137.1 30.2 -32.5
          Intelsat 805   55.5W 136.5 139.8 31.6 -30.8
                 Pas 9   58.0W 139.3 142.6 33.0 -29.1
              Amazonas   61.0W 142.8 146.1 34.5 -26.7
            EchoStar 3   61.5W 143.4 146.7 34.8 -26.3
             Rainbow 1   61.5W 143.4 146.7 34.8 -26.3
              Nahuel 1   71.8W 156.7 160.0 39.0 -17.1
             DirecTV 1   72.5W 157.7 161.0 39.2 -16.4
                 AMC 6   72.0W 157.0 160.3 39.0 -16.9
             Galaxy 12   74.0W 159.8 163.0 39.7 -14.9
                 SBS 6   74.0W 159.8 163.0 39.7 -14.9
               GOES 12   75.0W 161.2 164.4 39.9 -13.9
                 AMC 5   79.0W 166.9 170.2 40.8  -9.7
             DirecTV 3   81.8W 171.0 174.3 41.3  -6.7
                 AMC-9   83.0W 172.8 176.1 41.4  -5.4
          Brasilsat B3   84.0W 174.3 177.6 41.5  -4.3
              AMC 2/16   85.0W 175.8 179.1 41.6  -3.1
                 AMC 3   87.0W 178.8 182.1 41.7  -0.9
                  IA-8   89.0W 181.8 185.1 41.7   1.3
             Galaxy 11   91.0W 184.8 188.0 41.6   3.5
          Brasilsat B4   92.0W 186.3 189.5 41.5   4.7
             Telstar 6   93.0W 187.7 191.0 41.4   5.8
             Galaxy 3C   95.0W 190.7 194.0 41.1   7.9
             Telstar 5   97.0W 193.6 196.9 40.8  10.1
             Galaxy 4R   99.0W 196.5 199.8 40.3  12.2
                 AMC 4  101.0W 199.3 202.6 39.8  14.3
            Spaceway 1  102.0W 200.7 204.0 39.6  15.3
                 AMC 1  103.0W 202.1 205.4 39.2  16.3
                AMC 15  105.0W 204.9 208.2 38.6  18.3
           Anik F1/F1R  107.3W 207.9 211.2 37.8  20.4
             DirecTV 6  109.5W 210.8 214.1 36.9  22.4
            EchoStar 6  110.0W 211.4 214.7 36.7  22.9
            EchoStar 8  110.0W 211.4 214.7 36.7  22.9
               Anik F2  111.1W 212.8 216.1 36.2  23.8
         Solidaridad 2  113.0W 215.2 218.5 35.3  25.4
              SatMex 5  116.8W 219.7 223.0 33.4  28.4
             DirecTV 5  119.0W 222.2 225.5 32.2  30.0
 EchoStar 9/Telstar 13  121.0W 224.4 227.7 31.1  31.4
            Galaxy 10R  123.0W 226.6 229.9 30.0  32.8
             Galaxy 12  125.0W 228.7 232.0 28.8  34.0
         Galaxy 13/H 1  127.0W 230.7 234.0 27.6  35.2
  Telstar 7/Echostar 5  129.0W 232.7 236.0 26.3  36.3
                AMC 11  131.0W 234.6 237.9 25.0  37.4
             Galaxy 1R  133.0W 236.5 239.7 23.7  38.4
                AMC 10  135.0W 238.3 241.6 22.4  39.3
                 AMC 7  137.0W 240.0 243.3 21.0  40.2
                 AMC 8  139.0W 241.8 245.1 19.7  41.0
            EchoStar 1  148.0W 249.1 252.4 13.3  44.1
            EchoStar 2  148.0W 249.1 252.4 13.3  44.1
  www.SatelliteGuys.US
***Free To Air Forum***
Satellite Finder is (c) Copyright 2004, P. Lutus
viewsat 2000 and superdish config issue
RTR Sports gone?
