Troubleshooting help !!
BIGWHISE
Leesville, SC
Hey fellas,
I just wanted to say thanks for a great and informative website. I have been reading for about 2 days now trying to figure out my problem.
To make a long story short, I just moved my SuperDish (105w ,110w,119w ) today due to a tree that has grown alot in the last 5 years. I had been getting alot of lost signal errors, and found a better spot for it. I moved it with no problem, I have over 100% signal strength on all three.
Here is my problem.....when I run a checkswitch ( DP 34 ) I am only picking up the odd numbered transponders for 119. I have both odd and even for 105 and 110.
I am not picking up half the channels that I am paying for.
My question is the switch bad or the 119 LNB? :confused:
Thanks for the help;)
Swap the 119 line with the 110 and rerun the test, if it follows the line then next run a dumby line from the switch on the port that has the 119 to the 119 lnbf and rerun the test, if it still shows only odd then its the lnbf, if it shows all then its either the line or a faulty connector that you made.
Football in HD!
