Trouble with my new installation Dish 33 inch + SG2100
regisma
58
Hi,
I have installed my Fortec Star 80 centimeters Dish with a SG2100 motor.
My Latitude is 45.5 N and my Longitude is 73.8 W (Montreal, Canada)
I have set the Elevation angle of the motor to 45 degree and figured out in the SG2100 user manual that the Declinaison Angle of the dish to be 23.2 degree.
Then I have ensured that the motor is set to 0 degree and tried to align the dish to my True South (Magnetic South +16 Degree).
Then I have set my Longitude and my Latitude in My Digiwave Diamond through the Motor settings and specified USALS.
Then I have asked the IRD to point to AMC 6 (71.8W) so around 177.2 in my Azimuth.
I was able to just have a signal between 53 % to 67 % and a rough Quality of less than 10%.
Would it be easier to find a Satellite such Estrela do Sul1 at 61.5W that correspond to 180?
Does My LNB is damaged?
Note I have tried to ensure that my Mast is perfectly vertical.
thanks
Regis
Make sure the LNBF is straight up and down for your true south satellite and set it as far back from the dish/reflector as it can go in the holder.
http://www.lyngsat.com/sbs6.html
(SBS6) 74w I would use this satellite (ONN)
Your motor angles are good. And very rarely do you get a bad LNBF, it happens but not a lot. If all else fails remove the motor and see what quality you get with a fixed dish. If anything a motorized dish should give you better quality than a fixed dish as the whole dish skews as it follows the arc.
Sounds like to me that possibly you need to recheck your LNB LO settings and that you afre serching for a live transponder and symbol rate.
Wholeshoe
Hi,
Here are the info related to this LNB, do I need to change something in my receiver?
thanks
Regis
Digiwave Standard KU LNBF Single Linear 780:
LOW BAND HIGH BAND
INPUT FREQUENCY RANGE 10.70~11.70 GHz 11.70~12.20 GHz
REFLECTOR TYPE OFFSET
F/D RATIO 0.5~0.7
CROSS POL. ISOLATION 20dB (min.)
NOISE FIGURE 0.5 dB or better (typ.)
CONVERSION GAIN 55 dB (typical)
GAIN FLATNESS 0.5 dB / 27 MHz
OUTPUT FREQUENCY 950 ~ 1950 MHz 1100 ~ 2150 MHz
L.O. FREQUENCY 9.75 GHz 10.60 GHz
L.O. PHASE NOISE -55 dBc / Hz ( @ 1KHz )
-80 dBc / Hz ( @ 10KHz )
-100 dBc / Hz ( @ 100KHz )
OUTPUT POWER LEVEL (AT 1 dB GAIN COMPRESSION) 0 dBm
IMAGE REJECTION 45 dB (min.)
OUTPUT VSWR 2.5 : 1 (MAX.)
OUTPUT CONNECTOR 75Ohm F TYPE FEMALE
DC CURRENT CONSUMPTION 130 mA
OPERATING VOLTAGE (1) 11.5 ~ 14.0 V = VERTICAL POLARIZATION
(2) 16.0 ~ 19.0 V = HORIZONTAL POLARIZATION
(3) Continuous 22KHz 4KHz
HIGH BAND SELECTION
OPERATING TEMPERATURE -40 ~ +60
NOTE: This what I see on the LNB:
RF: 11.70/12.20GHz
IF 950/1450 MHz
LO: 10.750GHz
Gain 5.5 db
Noise 0.5 db
The menu should be very close to the CoolSat 4000 Pro.
Dish Setting:
- Satellite: AMC 6
- LNB Power: (On / Off / 13V / 18 V) is at ON presently
- LNB Type: (Single / Universal / OCS ) is at Universal
- LNB Freq. : ?????
- 22KHz: (ON / OFF) Presently already set to ON
- DISEqC : (OFF / 1.0 / 1.1) Presently set to OFF, I have not install it yet
Motorized Settings:
- Satellite: AMC 6
- LNB Freq. : ?????
- DISEqC Motor: (OFF / 1.2 / USALS) is at USALS
- Move: (<< East / Stop / West >>) now it show Stop
- Limit: Disable
- Antenna Position:
-- Sat Degree: 72.0W
-- Antenna Longitude: 073.8 W
-- Antenna Latitude: 045.5 N
thanks
Regis
vLooks like a Universial LNB
I do not have one but I think you have provided enough infor for some others on here to set you up with the right info.
I would guess on your receiver you want to choose Universial for LNB Type, 10600 and 9500 for you LNB Freq.
I think,
Wholeshoe
Watch out about the elevation angle on the Fortec dish. The scale on the dish isn't all that accurate. I think mine was somewhere around 6 to 8 degrees off. You might try peaking your dish like you did before and got 10% quality, and then try making small adjustments on the elevation of the dish.
Traxis 2500 DVB scan question/channels saved
At last.. my plans are coming to fruition...
