triple LNB install
stillersnc
Help!
After several hours on the roof, I was able to get signals for A, B, and C. The problem is that I have not been able to get any pair of the signals at once. If I have a 95 on A, I get 0 on B and C.
I have the integrated triple LNB and built-in multiswitch. Is this most likely a connection issue or a line of sight issue. The fact that I have been able to get signals on all 3 tells me it seems to be a connection issue but, although the dish is roof mounted, I do have trees extending 30-45 degress higher.
Rec settings (giving a 95 signal on A currently)
azimuth 227ish; elevation 37; tilt 55.
Sounds to me that your elevation setting for your dish is incorrect. You are most likely tuning the 101 WL location with either the 110 or 119 part of the triple LNBF. Make sure your mast is COMPLETELY PLUMB, then set your elevation to the suggested setting. Slowly move the dish antenna through the arc until you receive signal lock. Adjust for peak signal strength.
Al
Failed while loading series error
12way MULTI vs. Cascadable multiswitch question
