The problem is that 129 is marginal at best for this particular area. I also don't understand why this area would be designated western arc. I am about as far east in TN as you can go. I can see NC from my house.
My guess is some engineer says that since the Tri-Cities is on the western side of the Appalachian Mountains. That there is no way most people would have a clear LOS to the east or southeast sky for EA.
Dish says they have no information available - so they can't say.
So, I have gone from a 105 Superdish, to the 105 Superdish with 105 disconnected, to adding a 61.5 wing dish because the old 129 satellite was horrible for this area, to now ripping it all out and installing a 1000.2 dish which will have to be on the other side of my house because of LOS issues with 129. (Try diagramming that sentence.)
Or, I can live with SD locals.
I believe I will live with it until Dish decides what they are going to do.
There are a lot of markets and satellites are expensive. Ciel 2 at 129W was designed to cover nearly all of the U.S. with spot beams for providing locals. The satellites at 72.7 and 77 only have ConUS beams which means their transponders can be used only once. The 61.5 position has spot beams but due to power problems it cannot utilize all of them. Eastern arc was conceived to be able to serve markets in the east that could not be served from the west. Also keep in mind that by law both DBS companies have to carry all available locals, not just the Big 4, in a few years further consuming transponder space. I would expect to see only the larger markets in the interior midwest and east on both arcs.
I wonder if that would include sub channels or the multi cast channels carried by the local networks also?
Have you looked at receiving them ota??? Being high up you may be able to get a great signal ota.
I don't need to know anything more. I know what I have to do to get 129. I suppose that Dish has never changed their stance on anything, so I should take their stance on Western arc as pure forever gospel. Just like I took their stance that a 61.5 wing dish was my best option for HD and that they would mirror everything from 129.
Has anyone noticed any signal loss on the Tri Cities HD channels? I Tuned to WJHL and it said signal lost, so I checked my signal strengths from 110. 118.7, 119, and the rest of the 129 transponders and they were from mid 70's to mid 80's. I think they have a problem with there spotbeam for this area.
