Torque wrench
Your diagram shows adding a wing dish to a Superdish, both with DP lnb's, the 1000.4 has DPP lnb with built in switch. If 3 or less receivers are being used with the 1000.4, the DPP44 external switch is not needed.
sorry again guys I dont much about technical terms but in fact I dont have what mancenta as describeb a dpp44 but rather to TheKrell that is a DP Plus with built in switches, 3 outputs and on input. So now being clear do I need only my receiver cable connected to one output and leave the others free, if of course the 3 satellite ,61.5, 72.7 and 77 have beeb aligned.
Hi,
Is it really necessary to adjust the dish mast perfectly on level, otherwise it could be somehow difficult to find and aligned the satellites.
Hi,
Finally my dish 1000.4 was installed but the only issue is that satellite 77 doesn't brodcats, in the system info from the menu of the TV satellite 77 has a red square with a white cross under it, i did a resetting ,I unplug the vip 211 about 20 minutes, but no can do, but I have all hd and sd channels as usual.
Hi,
Thanks garys, I'm glad to known that, indeed I have all my hd and sd channels.
ABC HD quality ?????
Dish Network Profits Fall as Revenue Misses Estimates, Costs Rise
