Getting ready to watch LENO in HD....first night with the new setup. Can't wait!!!
Congrats! You will LOVE IT! I hope you can get more of your locals but understand that even one is GREAT!
</IMG>
Do you get a blip of a signal for the other networks? If your 811 is stuck at 49% for those you might be able to get them with a newer tuner.
I'm also curious to how your analog reception looks.
i have the 4228 gettin OTA 75 miles from raleigh stations and my friend has 4228 getting raleigh stations from 85 miles away all in the 70's-90's..sometimes even 100%
Like hpman247, I'm about 75 mi. from Raleigh (27870 zip). I'm tired of waiting to get HD locals through E* (ABC/PBS don't count in my book) but shudder at switching to D* just to get CBS. I don't have a problem installing the OTA antenna but the wife won't like the idea of a big antenna and pole on the roof. Any ideas about what kind of reception loss I would expect to get if tried mounting it in the attic(single-story)? Any suggestions on what antenna/pre-amp to to purchase? My TV doesn't have an HD tuner so I'm probably going to upgrade my package from the AEP-SD to the Top250 HD w/ DVR Advantage (I currently have a 522).
Any advice would be appreciated.
So what's your signal strength Jimmy ?
Out here we have no Fox HD OTA. I'm patiently waiting for them to get the FCC license to do this, but sometimes I think I should just try to get the one 100+ miles away (but I know I won't be able to reach, even with flat terrain).
I only ask about analog becuase the digital signal is supposed to replicate the coverage area of the analog signal. You can also use it to see if you are getting multipath.
I've owned several OTA tuners and my 811 is the weakest, I don't know what generation it has but I think its too old to have a 4th gen. Usually my 811 will be stuck at 49% when my tv's tuner can decode the signal.
The 811's tuner certainly is the weakest I've encountered as well. However, my experiences are with a Zenith ATSC standalone STB, a Dish 6000 8VSB ATSC tuner, the 811 ATSC tuner, and now the 622 tuner. The 622 is definately the best. I actually was able to get three extra stations coming from a 90 degree rotation from where my antenna was pointed when I did my channel scan.
If you are having some blips of signal strength and it locks up at 49%, then you can bet any other ATSC tuner will be able to pull it in adequately to watch.
If I read your post right, your new Winegard vhf is in addition to the CM4228, both for digital? If that's correct you will probably have some issues trying to combine the two antennas. My father-in-law next door tried this, mounting one above the other making sure to keep enough clearance between the two. One was a vhf/uhf combo (a very large one) and one was a uhf only. He never was able to get it to work so he abandoned that for the uhf only.
That's a sweet little amp! I may have to consider one for myself if I continue to dabble in getting as many stations in as I can get. I'm lucky in my location because I'm smack dab in the middle between two DMA's and I easily get signals from each (Tyler/Longview and Shreveport). As I mentioned before, I can also receive Dallas locals from two stations after sunset. However, that amp may make that better. Right now though, I get ABC, CBS, NBC (the Tyler one that does HD now), and Fox and I really don't need anything more.
