I have a Dish 942 and a Dish 625. I have created a whole house network with the 3 SD RF outputs available to me. I just have a question about what kind of signal combiner that I could use to improve the signal quality.
Here's what I did:
On the back of the 625 I took TV1 out (channel 3) and TV2 out (channel 21) I used a dual antenna combiner to combine those two signals and send them down a wire. I took that joined signal and used a another combiner to add the TV2 out (channel 30) from the 942. I then took this super signal and fed it into a 4 way output block. I sent this output to 4 different SD tv sets. I set each of the TV's to tune channels 3, 21 and 30. Presto, each of the sets gets a pretty good feed from any one of the 3 tuners that are available to them.
The 942's HD output just feeds one of my HD tv's. My other HD tv is using my old Voom box to just get the HD Digital OTA channels.
What I would like to do is join all of the SD feeds and also the analog TV channels from my OTA antenna. The splitter / combiners that I have found locally all filter all but one of the inputs, so it doesn't allow multiple feeds onto the common bus. Is there a real combiner that would let me have 4 SD Analog inputs feeding 4 Analog outputs and combine all of the signals without filtering?
Here's what I did:
