Backstory: I’m a nine-year DTV customer still using a triple LNB and HR10-250’s. I thought I might join modern society and upgrade to a Genie with three clients. I expect that I’ll be offered a free upgrade w/ installation, however, I want to install (mount) the dish myself. I plan on having the equipment installed and the dish aligned by DTV, but I wanted to do the dish myself. I’m retired now and have the time and inclination to do this. I’ve done some pretty extensive research on this but that said, I need some guidance on some things I’m not clear about and that’s where all of your collective experience can help me. THANKS IN ADVANCE FOR ALL YOUR HELP. Lets dive right in:
1. I have already mounted the dish in a good location with an easy 10-degree clearance. No issues there. I’ve read some conflicting information on mounting. Some people have said “no custom mounts at all” while others have said that it just needs to be mounted securely with 2 and 3-inch lag screws. While I did fabricate a “custom” mount, the dish is nevertheless attached directly to the house. The monopoles are attached with 4-1/2” lags into studs and the base uses all 3-inch lags that go into the rim joist or top plates. So, everything is into solid wood. My concern is that the tech may refuse the install due to the possibility that it would fail a QC inspection because it’s “custom”. I’m I being overly concerned? BTW, my market is OMAHA and i’m not sure who does the installs here.
2. Grounding. Oh yeah, I forget to mention I’m installing the ground rod and bonding it back to the service ground myself. With a SWiM LNB do you use a single or dual ground block? If dual, does the Tech run dual RG6 into the house or just cap off the unused port?
3. If you were installing this where would you place the ground block? The cable feed thru would have to be located below the mount.
Tom
Tom
