....TiVo does not need to prove infringement on receivers already adjudged to infringe. DISH/SATS needs to prove those no longer infringe, and that may not be enough to escape the disable order in the injunction.
The law says an infringer can modify the adjudicated devices in order to design around the patent. The 4 million DVRs most certainly fall into the adjudicated devices category.
The law says in a contempt proceeding, when there is design around, the patentee must prove with clear and convincing evidence the design around still infringes.
The law also says if the infringer can establish the doubt that the accused devices (in this case, the 4 million DVRs with the new software) may no longer infringe, then a contempt will not be appropraite, the patentee must seek a new action, or a new lawsuit.
In any summary proceedings, which the contempt proceeding is one of them, the mover (TiVo) must prove with clear and convincing evidence, not the non-mover (DISH). The non-mover only needs to establish the doubt to avoid a contempt.
All of the above what I said are based on the law, I have quotes for all of the above, you know it.
Your notion that E* must prove non-infringement in a summary proceeding has no basis, you never quoted the law anywhere that the non-mover has the burden of proof in a summary proceeding. It is the opposite, the mover must prove with clear and concincing evidence in order to get the contempt charge they want on the defendant.
The only times you have ever found cases where the non-movers had failed were when the non-movers never tried to design around the patent, or the design around was only colorable, meaning in bad faith.
A good faith design around has always helped an infringer to avoid a contempt charge, no exception, regardless if the products were adjudicated already or not, or if the adjudicated products were already in the field or not, and it does not even matter what the context of the injunction was. When there was doubt whether infringement still existed, there was no contempt, period.
