tired of just getting memphis stations at night so.....
Good luck. According to Solid Signals listing for your UHF antenna it is rated for 60 miles the stations you are trying to receive are 75 miles away. Using the TVfool report Ice posted you have 2 LOS signals when a 10ft mast is selected. At 50 ft. LOS goes up to 5 so you definitely have a heigth problem. With most of your stations listed as 2 edge you need to maximize all reception factors to accomplish your goal.
You need a better antenna and a tower, the CM7777 should work well and aiming the antenna around 250 degrees may work for your location. $$$$$$ is part of the cure and good luck after the changes are made may give you Memphis stations.
thanks. but the only antenna thats any better is the xg91 correct? I can't put alot of money into it. so, i may just have to give up on getting memphis.
