Timers not updating (Spring Forward Problem?)
reseman5
17
I just checked all of my timers and they are all off by 1 hour. The guide and everything shows the right time, but when I check the schedule it is recording the program that is on an hour before the actual program. I have rebooted and still no change.
Before I setup all new timers, wanted to see if anyone had a quicker fix.
Fine here
I don't have any ideas for you but they're correct on my 622.
Generally, the timers I set within the last week are wrong (in the samw way you said), and the ones that are older are still fine...
I went to the scheduled update time in the Menu Preferences and changed the time to update now (such as 3:30 PM). I then watched it go through the update process. When it rebooted this time, everything was back to normal. I then changed the update time back to 3:00 AM. Maybe try that.
Any chance you had a timer recording when the update was supposed to happen at 3AM? If so, then perhaps it didn't correct until you forced it manually.
HD Upgrade without HD TV's
Program guide all screwed up
