1. Get DishComm and Broadband enabled on the 211 and 222 receivers. Enable them to have external hard-drives.
2. Get rid of HD Access Fee.
3. Replace the 625 with 722 in all New Connect promotions.
4. Replace the 311 and 322 with the 211 and 222 respectively.
5. Make 1000.2 the standard dish.
6. New inventory is only 722, 612, 222, 211. This makes all new receivers capable of broadband and seeing each other. Should eliminate many AO fees.
7. a. Create a device similar to NetGear XE102 and allow retailer to get reimbursed extra for receivers that have a broadband connection. That will cover the cost of the device.
b. Create a wireless adapter similar to a game adapter that can connect to the Ethernet port on the receivers, the above reimbursement could offset this device's costs as well.
The above steps will allow Dish to get a better handle on where their equipment is and allow PPV impulse and DishOnline buys.
8. Convert more PPV channels to Mpeg4 and upgrade those customers who buy PPVs to Mpeg4 receivers.
9. Convert TEN, Exstacy, etc., to Mpeg4 and upgrade those customers.
10. Convert sport packages like Center Ice, Extra Innings, cricket, etc. to Mpeg4 and upgrade those customers.
11. Same for movie channels, then AT250, etc.
The goal of the above transitions is to get away from the Mpeg2 standard to allow more channels via mpeg4 without forcing a big swap-out to occur at one time. If those hacked FTA receivers can't do Dish's Mpeg4, then this transition would be even more worthwhile since the high-revenue programs would be first to get protected.
Finally, make a module that has the separator built in that just slides onto the Sat 1 and Sat 2 ports and can be screwed onto the receiver. Matter of fact, ship the receivers with the unit attached. Those who don't need the separator can unscrew the module and connect direct to Sat 1 and Sat 2.
I would go so far as to even suggest they build a splitter and diplexer directly inside the dual tuner receivers. That way, SAT 2 can have a diplexed backfeed of TV2, leaving the one coax connection a possibility with the above module. By splitting internally, the normal TV 2 output is preserved. This could save on lots of inhouse labor by letting techs cut fewer jumpers and connections. It would also reduce the number of fail points in the typical install.
