Ok, got my FTA setup from Sadoun, in which the signal meter I ordered is on backorder....anyways, Got the Mercury 2, Univ LNB, 31" Dish, HH90 motor...tried setting this thing up and its a nightmare!
Do I use the USALS setup or the Diseq 1.2 setup? My latitude is 34 and My longitude is 82. I know my true south is about 6 degrees more than the magnetic south on the compass...I set my latitude on the HH90 to 34 degrees as it said, set my dish elevation to 39.5 degrees as it said on the sadoun website....tried finding AMC-9 or 3 at 83 degrees and could not...the pole is firmly level, no obstructions, adjusted elevation on the dish by 1 degree both ways, made sure it is all connected correct and still no signal on AMC at 83 degrees...
So my question, how in the world can you find your true south perfectly with a compass and a protractor...because I guess thats why I am not getting a signal.
Then I took the motor off and printed out the list of what's up there to find a fixed location to scan, so I chose Galaxy 10ku at 123 degrees (got the dish az and elev from the web), got it w/o using the motor at about 70% signal level and a little lower signal quality--did the power scan and only got about 2 in the clear channels, one being KBS, and about 9 scrambled channels---is this all that is on this satellite b/c I've heard you all talk about G10R is a good one to lock in on but I got nothing.....what am I doing wrong? These manuals suck majorly! Can someone please make a quick explanantion of what I need to do to get this thing working? And am I only going to get a few channels here and there w/ this or will I actually feel like its worth the money when I get it working?
