I've read several posts on this topic, but I have a few questions I hope someone is willing to answer:
I have (2) 322 receivers at home. I plan to bring one to the cottage and leave it there. I would like HD at home, so I plan to buy a HD receiver (ebay or dishnetwork) and put it at home. Then, leave one of the 322 receivers at the cottage. I'll pay Dishnetwork for all of the additional receivers (2 additional receivers).
At the cottage I have a dish that says "dishnetwork 500" on it. It's round. It has a wide LNB with 110 and 119 and connections for two coax cables.
It sounds like I can connect the 322 to that dish. I tried it with no luck- here's what I think the problem was?
I ran one coax from 119 on the dish to the receiver (plugged into dish #1 port on back). I did not run switch check.
1. Should I use DP separator or am I ok with one cable?
2. Do I need to run switch check because I'm on a different dish?
3. Does the switch test, test connectivity to the LNB so I know I have a good dish?
4. Do you think I'll trigger an audit because the cottage receiver will not be plugged into a phone jack?
5. As I point this dish, how exact to I need to be to get any type of signal- 2 degrees, 5 degrees?
