Cascade said:My Inspiron 9300 can run as low as 300MHz if it needs to which gives it a great runtime.
Stargazer said:So the Inspiron 9300 allows you to set the speed that you want to run it at or does it just have certain set levels that you can set it to such as very low, low, med, high, etc.?
Cascade said:Toshibas are underrated machines, the only thing you'll find with the faster CPU is that your batterylife will be shorter.
If you can find a machine with a Pentium-M CPU you'll be set. Centrino laptops all have the Pentium-M CPU and are designed for longer batterylife.
The CPU speed is generally slower however the larger cache (2MB on the new chips) More than makes up for it.
Scott Greczkowski said:I think he means smartcards as in the memory cards digital cameras use. I know of no laptop with a DishNetwork / DirecTV smartcard reader built in.![]()
Flawed how?T2k said:OS X is great in many ways but also flawed in several ways.
TuxCoder said:Flawed how?
hdtvtechno said:I Just brought A Dell Inspiron 9100 on ebay![]()
OS X is built on BSD.... How the hell does that make it the kernel thats flawed??Cascade said:The kernal![]()
rharper83 said:OS X is built on BSD.... How the hell does that make it the kernel thats flawed??
TuxCoder said:I see you're apparently in the UK
