Hi,
I presently have a customer that I prewired and installed this system sometime ago. He has 2- 625 DVR and 2 311 receivers. This job was completed before they came out with the DishPrpPlus lnbs.
Used a dish 500 to feed a DP34 switch then another 34 switch. Each of the 625 receivers have 2 inbound coax from the dp34 switch.
Now my customer is wanting to trade in one of the 625 for a 622 HD.
I looking for the best way to connect it all. I know if I use a dish 1000 there will only be 3 ports out and I'll need four due to having four receivers. I could get rid of the dp34 switches and replace with the dp44plus switch but then I have to change all the wiring.
I know from experience that you don't have near the signal strength with the 1000 that you have with a 500 dish for sat 119 & 110.
Now my question is: Can I put up another 500 and point it at 129 and feed it into the dp34 switches? What kind of signal stength do you get? With the 1000 dish I have been getting signal strength on 129 from 66 to 87 depending on the trasponder.
