2 questions. Will an accutrak ka/ku meter give an accurate signal reading when using a swm8, and is there a simple way to test the Power Inserter to see if it's functioning properly (other than the green light)?
My system IS connected properly, I've been on other forums and no one seems to have an answer for my problem, which is the always searching for signal. After installing swm, went from having configuration confirmed, having signal, to lockup, no signal, searching for signal sat in 1 and 2, can't verify config. Have reset a hundred times, powered down, unplugged, tested EVERY connection and cable, and still can't get a signal. Connect dish directly to receiver (hr21, 2 months old), no problem, signal strength in the mid 90's to 100. With swm in line, signal reduces all the way to the mid 40's @ the power inserter. Cable run is well under max length, no splitters, only on receiver. Any suggestions? Would appreciate any help. Ready to throw the whole mess in the street.
