SWM 16 help please!
Satellites 101, 99c, 103ca, 103cb are 0 on all the odd. Just realizing that I'm not even seeing satellites 110, 119, 99s & 103s aren't even showing as options to check.
The 1st cable we disconnected seemed to be the issue reading began appearing on all the 101 transponders. We replaced the connection and everything seems to be in working order. I now have satellites 101, 99c, 99s, 103s, 103ca, 103cb. The channels we had issues with before currently seem fine. Before we did the wires I saw satellites 110 & 119 but they aren't showing anymore. Should I be concerned about that?
All my transponders are mid to high 90s for the most part except on 99s. Those readings are:
1-8 35 0 33 0 77 0 - -
9-16 - - - - - - 0 99
25-32 50 71 99 99 0 0 0 0
I believe those are about what I had before we changed the wires.
99s and 103s are spot beams. Don't worry about them.
With a sl3 lnb, you shouldn't see 110 or 119 at all.
OK great. Thanks, Chip, jcrandall, twitz3dkitty & texasbrit! And thank you to all that have helped! I think we may be in the clear now which is a great relief.
Reactions: raoul5788
Just so you know, the 99s you referenced is as mentioned a spotbeam and normally where your Local channels come from, not knowing where your at, your signals show 99 on 3 of them, one of those transponders is where your locals are coming from. the other two could be from a city close by.
Second receiver pixelates
MTV2 HD
