Switch test wrong - 311 receiver, legacy Dish500 + sw21 for 148,
dschmidt
Hello, I'm hoping someone out there can help me.
I've got a legacy system running well for the past 6 years (dish500 quad, sw21 to another single lnb dish pointed at 148, PVR501).
I want to set up another receiver to feed into my PC for recording shows automatically using SAGE.
I've duplicated another drop into the room where the PC is - RG6 'swept' cable, Sw21, everything checks out. Friend brought over his receiver (model 4700) and switch test is good, sees all 3 satellites. I also tried my PVR501 in the other room and it too works fine.
Bought a model 311 from Ebay, plugged it in, did a switch test with nothing hooked up (per searching the threads here), then hooked up the satellite antenna and ran the switch test again. I only see satellites 119 and 148. Repeated the switch test again, same results. Tried my PVR501 - everything is fine, can see 110, 119 and 148 with good strength.
Anyone know what could be wrong? Can the 311 work with a legacy Dish500 + Sw21 + single feed lnbf pointed at 148?
311 switch test looks like this:
Input 1 1 1 1 2 2
Sat 119 119 X X 148 148
Pol odd evn X X odd evn
SuperDish and Alternate are not checked.
Thanks,
Dave
sure the 311 can work with that setup. I use to have a 301 (same model..card not built in) running 110/119/148 with a Sw21 swtup
Try and run the check switch with nothing hooked up to clear it out. Then rehook up and run check switch
It might just need a software upgrade. I seem to recall some 301/311 receivers having a problem with 110 until the current software version is downloaded to the receiver.
Reboot it. When it finishes the 5 tests, power it off with the remote. In a few minutes it 'should' start the download. When it's done, do another reset and checkswitch.
Thanks! Looks like the FW was it!
Originally it was P317 so I left it powered up off overnight and today the FW is P435 and the check switch worked fine. Thanks!
Now I have to figure out how to re-set up my SageTV PC.
Dave
What hd dish will I recieve?
Central wisconsin may lose its Fox on locals
