Switch Help - DP34
rwithclass
9
I have 148 ( Dual ) - I thing its Single DishPro, it looks like this
http://www.sadoun.com/Sat/Products/Dishnetwork/LNBF/DishProTwin.jpg
I have Dish Twin Pro - 110/119
http://www.sadoun.com/Sat/Products/Dishnetwork/LNBF/DishPro_Twin.gif
Now I have 3 Recievers, ( all 301 )
Is Dp34 the one I need, can someone direct me which one exactly as I got lost abt the power supply one
The only inconvenience I have is that my 110/119 are with 2 Single DishPro ( Dual ) and the coax's ( 4 of them ) are already coming out of them
Without removing them and putting my DishTwin Pro, can the DP34 work or is there some other solution
Thanx
Thanx
Call 1-800-333-3474 and sign up for DHPP a service call will cost you $29.99:)
I have 148 ( Dual ) - I thing its Single DishPro... The only inconvenience I have is that my 110/119 are with 2 Single DishPro ( Dual ) and the coax's ( 4 of them ) are already coming out... Without removing them and putting my DishTwin Pro, can the DP34 work
Yes, that will work. With DishPro, you only need one coax per satellite location. So you just leave one coax from each dual (110 and 119) disconnected. The 3rd input will be coming from your wing dish (148). Make sure your LNBs are all DP, or this definitely will not work!
The dp34 doesn't use a power injector; your 301's have enough oomph to power it and your 3 lnbs.
Sometimes sw34 switches can be a pita.
It would be cheaper to get a Dish 1000.2 and wire the 148 dish to port 4 on the 1000.2 lnb.
fred
It doesn't make sense that you have two lines coming out of each dual unless they were previously connected to a switch. The only switch that would require two lines out of each dual lnb would be a Legacy model. Legacy LNB's don't work with DP34 switches. What exactly do you have and what are you trying to do?
No Red Wings on FSN-HD (Channel 380) in Detroit!!??
722 HD Sound Problem
