Superdish LNB
STDog
322
133
Looks like I need to replace the LNBs on my Superdish 105.
currently has a DP dual and a shared housing for a DP (dual?) and the FSS for 105.
Currently I have a Dish500 with 2 duals, and a SW21 feeding a 4900 receiver after the DP adapter broke.
When the Superdish was installed they took my SW44. So the Superdish now feeds a 501 and a 301 through a DP34.
What are the options for replacing the 110 and 119 LNBs?
Any one manage to get a DP twin to fit it?
DP twins are much cheaper than 2 single.
Or should I just get a legacy quad and put it on my Dish500?
(a SW44 is hard to find and not as cheap as the quad)
Don't need the FSS LNB as 105 is unused.
The issue is the DP Twin is cheapest, then the legacy quad, and 2 DP duals most expensive.
The 4900 is in use, but as I said they took my SW44 when they put in the SD and DP34. Only reason they left the Dish 500 is it's on the roof and the guy didn't want to climb up there. I wanted all the old stuff left.
A pm mentioned the spacing between the LNBs on the SD is different, so I guess I'll go find a quad and pull the SD out.
I never liked where it is, ground pole and a pain to mow/trim around.
1000.4 - Can't see 2 sats at once
AMC 14 Status?
