Hi All:
Hopefully someone here can help me with getting my Superdish working... I purchased it on eBay (yes I know...) Set it up and ran test switch (DLP44) it came up no connection on two of the LNBs. Ok Thought it may be a bad LNB so I purchased a replacement, Same result; no connection... It appears that the LNBs aren't compatible with the DLP44?? The DLP44 tests ok with the dual "DP" LNB that was included with both purchases... Any insight into what I'm missing would be helpful....
The failed LNB info:
Set one
DBS Stacked LNB
Part number 122676, Lot P51 ADS08014598
FSS Stacked LNB
Part number 122677, Lot P51 TA5DS09027203
Set two
DBS Stacked LNB
Part number 122676, Lot P45 TE4DS08008767
FSS Stacked LNB
Part number 122677, Lot p45 1E5DS09041902
Set one
DBS Stacked LNB
FSS Stacked LNB
Set two
DBS Stacked LNB
FSS Stacked LNB
