Hi,
I have a SuperDish 121 setup and I am having some problems. I was hoping someone may be able to help me out.
I have DP301 Receiver with a DP34 Switch. Trying to connect 110, 119, and 121 to this receiver.
Using the DP34 and one LNB at a time on connection (1) on the Switch, each signal shows up on the receiver point dish signal screen. However when I connect all 3 LNBs to the Switch, and perform a check switch, It shows that the DP34 seems to be working, but there is a N.C. (no connection I'm assuming) mark on all 3 satellite inputs.
Any ideas what the problem might be? Any solutions to my problem?
Thanks for Reading.
Fil
I'be been trying a different switch that is supposed to do the same thing as the DP34 but has 4 LNB inputs.
Its odd, but i've been having better luck with it...to some degree. If I connect 121 and 119, they both work but as soon as I connect 110 along with the other, it seems only 110 is detected.
I have no clue what is happening. Anyhelp getting either one of those problems resolved would be greatly appreciated.
Thanks again.
Thanks for Reading.
Fil
Thanks again.
