X xmad_manx New Member Original poster Aug 11, 2005 2 0 Aug 11, 2005 #1 Hi, Would hooking up a superdish 121 lnb to a 30’ or 33’ dish work, if not how about using those 3 lnb holders? Thanks
K kavula SatelliteGuys Pro May 30, 2005 217 0 Aug 11, 2005 #2 I think a 30 foot dish would work very well! A 30" or 33" dish would come close to the recommendation (IIRC) of a 36" dish. You might get a slightly less reliable signal. I wouldn't know how to attach to LNB to the dish without more information.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 2,756 12,106 Mankato, MN Aug 11, 2005 #3 a 30" dish would work fine for 121 or 105
X xmad_manx New Member Original poster Aug 11, 2005 2 0 Aug 11, 2005 #4 So hooking up 3 lnbs or a superdish lnb assembly to a 30' would serve as a superdish, what switches I should use? I have a 4900 receiver.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 2,756 12,106 Mankato, MN Aug 11, 2005 #5 If you go with DishPro, you would need a DP34 and a Legacy adapter sicne the 4900 is Legacy If you go with Legacy, you can use a KU band LNB, a Legacy Twin and a SW21 (easiest in my opinion)
J jergenf SatelliteGuys Pro Mar 15, 2005 378 0 Aug 11, 2005 #6 Do you get Martian TV? Do you really have a 30 foot dish or did you mean 30 inches?
webbydude SatelliteGuys Master Feb 6, 2005 5,339 1 Akron, Ohio, United States Aug 11, 2005 #7 Wow! Can you imagine the total lack of rainfade if it IS a 30 footer?
