How would you rate a type 2 dish overall, and what do they run price wise?farmsatguy said:Are you having problems with your 105 channels? If not, then leave things alone would be my advice. The 105 sat needs a signal strength above 35 or it wont lock in - I would bet you have a type 1 metal super dish, but misalignement isn't your problem (unless 119 & 110 are low too - what are they?) Since your well above 35, you should be fine. As an installer, the higher you try to get the 105, the more you will drop the 119 feed when adjusting the dish. I can get a type 2 dish in the 70's all day, but the type 1 is a different story. So, to use one of Murphy's Laws (I think it was him anyway), if it's not broke, don't try to fix it! It just p*sses us installers off when it turns into a trouble call! LOL
There are several suppliers that have inline amps for Sattelite equipment. Starlink-DSS, Sadoun, even Monster cable has them. And refering to a digital signal, do you know how a one and a 0 are acheived? Does 4.6 and 6.4 volts dc ring a bell? A digital freq. still is electricity. Without the electricity, and magnetism, you have absolutely nothing but glazed sand!!!DishSatUser said:I don't believe a Dish Pro or even legacy Dish LNB "in-line amp" exists. You can't use the same in-line amps that are produced for the Cable TV market. Primarily due to the fact that the Dish system supplies voltage to the LNB's to operate and the commands that are sent via DisQueC on the Dish Pro equipment.
Also, in-line amps help to boost "analog" signals, but the Dish equipment is all digital anyways. Them 1 and 0's might be "louder", but the missing digital information from the poor signal won't be replaced with the in-line amp.
