Suggestions with a 250' coax run?
shadetree1
16
Iowa, USA
I live in a forest and that is as close as I can get.
New setup (wife approved) 10' unimesh dish, C/Ku Lnbf, DiSEqC positioner, with my CW LMC-4000HD.
The DVB-S2 tuner runs 400 mA and I'm worried about the internal DiSEqC switch and DC at the LNBs.
I'm thinking by the specs of the RG-11 BC, the 14ga pure copper conductor will work and way better than the various RG-11 CCS cables.
Thank you for any help!
If you are going to bury the run be sure the coax is designed for direct burial.
Be sure the cable is well shielded. Quad shielding if cable will be aerial.
Be sure fittings are the best, seal tightly and are water proof. If you don't have the correct tools for RG11 find someone who does. Great cable with poorly applied fittings will cause you problems.
My "wife approved" farm is a little under 300 feet from my house and I am
running only RG6 with no problems. You might consider putting your coax
inside of schedule 40 conduit for added protection and possibly making it
easier to run more cable in the future without digging. Insert a small
diameter rope along with the coax so you can pull another run in the future.
I used 1 1/4" conduit but for a little more money I could of went
1 1/2" and skipped dinner with the wife! ;)
Hi jimdandyvi,
The cable will be flooded burial, have adjustable dies to RG-11 in my snap/seal tool, but have you any experience with the DC at long cable runs?
I can not find a 300' piece of this type of cable to purchase and temporary hook up and try but CCS.
Thanks.
I used 1 1/4" conduit but for a little money I could of went
Yes, I also was thinking about future upgrade cables/repairs using conduit.
On your successful long cable run, are you using a pollinator servo LNB or a single cable LNBF?
Thanks, Dishman Dan.
...are you using a pollinator servo LNB or a single cable LNBF?
Currently I am running a DMX741 LNBF on my 10' Channelmaster and running
a coax for C band and another coax for Ku. It is actually satellite ribbon cable so
I can set up a LNB and the servo wires are there. I also have another coax going to
my 1M Ku dish along with a couple extra coax cables for future plus a spare ribbon
cable for ??? ;)
Channelmaster and running a coax for C band and another coax for Ku.
Great, so polarization switching at that length is no problem for you using the RG-6 DC voltage.:)
Have you ever tested the internal DiSEqC switch of the DMX741 using just one RG-6 cable for C/Ku successfully?
I'm asking as this is the LNBF I have chosen to use too.
It has been working great for me! :up
I have the "separates" hooked to my DSR922 4DTV and
never tried the internal switch. In the house I have splitters
where I tap in my OpenBox for C band and use a DiSEqC
switch for C or Ku. The 1M is currently dedicated to
History until I get my 4DTV subbed this fall. This works for
me until I get dedicated BUDs set up for FTA and 4DTV!
Looks like I better take my wife to dinner with that idea! :eek:
switch for C or Ku.
I was wanting to avoid two cable runs with switching inside the house.
OK, I see what you are going to do.
Yes I may need to do the same if I can't switch at the LNBF. I would need two runs of coax and larger conduit.;)
Thank you much for your help.
If I find the time I could try the inside switch and see how it does! :eureka:
One more thing...
The DMX741 lnbf works well for me on the BUD for Ku.
However we get a lot of "lake effect" snow! In the fall and early spring
it is a wet snow and at night when the temperature dips it freezes on
the BUD. It does not take much to knock out the Ku with that wet
frozen crud so that is why I want a separate smaller Ku dish. :smow:
I appreciate your efforts trying the internal LNBF switch at your coax range.
I have a motorized 42" with a quad invicom I use for Ku but thought I might test Ku on the 10'.
If every thing works as planed, I have a 18" motor with a manual positioner that I'm adapting to use with the BUD for vertical finetune. (I know, over Kill) ;)
My CW-LMC has 4 tuners so after the BUD setup is finished, I'm hoping to test any signal.:D
How to set skew for orthomode feed?
AMC 15/18 at 105 W
