I'll at my experience with Fortec Star C band dishes. They are a royal pain! I have the stationary ground mounts, nothing moving. The 6 footer I have for reception of AMC1 at 103W. I finally got it aligned, but getting it to that point was a royal pain. What I'd adjust most is not the azimuth or elevation, but the skew, focal depth, f/D ratio and positioning of the scalar ring and feedhorn. The arms are thin, and do not hold the scalar ring at the right position. It requires adjusting and playing around to get it perfect. It requires lots of this tweaking with heavy LNBs and feedhorns, like Norsat LNBs and Chaparral feedhorns. The weight weighs it down and makes it a pain to find the sweet spot. I had to get a Maxpeak signal meter to properly align it. It fell down the 60ft ravine behind my garage, so I had to purchase some new panels because some got really bent. The dish is perminantly pointed to AMC1, for DW-TV and Deutsche Welle Radio.
I have an 8 foot Fortec as well. I found this dish easier to pull in signal, because the reflector is larger. Initally, I had it pointed to AMC11, for Weather Channel analog and QVC digital. I then pointed it to Galaxy 14 for Music Choice (which I miss terribly). I finally pointed it to AMC10 for the Weather Channel digital and Discovery digital. It will stay where it is for good. I'm either going to try to add another feedhorn and LNB for Music Choice at Galaxy 14 or put up another dish. AMC10 is at a very low elevation at my location, so pointing it was a major pain. It, too, had to have the scalar ring position peaked and adjusted, just as much of a pain as the 6 footer. Eventually, I got both pretty good where I'd get a decent signal. It was a royal pain, but I got it.
Jonathan
