Still Aiming ...
I think those that are seeing the 121 when aimed at 119 are seeing first hand why 121 wreaks havoc on the Tube's transponder :).
i agree shawn, i could have swore i had my BUD pointed at 119 and hit a dish 121 barker, but it must have been because the sats are so close together i was picking 121's barker.
sidekick said:
So ... if I "do" see a 121 card, I'm not on 119.... right?
As Iceberg said, you shouldn't see 121 when aimed at 119.
With a linear LNB, you might. you may also have mixed results seeing the FTA stuff on 119. I solved this problem by using a circular LNB when gunning for 119. With my linear Ku LNB I'd sometimes get the 121 card with the dish aimed at 119. The circular LNB won't see 121 at all :).
ahhhhhhhhhh i was pointing a linear LNB at 119, ill bet that is why i got the 121 barker.
Hello Gama, the 148w satellite is over the Pacific so that should be easier for you to pick up, but there is not a lot FTA there?
Good Luck!
LNB port caps
Could hackers spoil it for us?
