Tell us more about your system....
Satellite:
Dish:
LNB Type:
LO Frequency:
Motor:
Switches and types:
Satellite Software:
Settings in software:
Satellite:
LNB Type:
LO Frequency:
Power:
Switch:
Transponder Frequency: , Polarity: , Symbol Rate:
What do you mean, "Hooked up to 13 / 18 V"?
Are you receiving Signal Quality or just Signal Strength?
Did the installer confirm the dish was aimed? If so, what satellite wa it aimed at? Did he use a meter to tell you what satellite it was aimed at? Did he test both horizontal and vertical polarities to determine that the LNBF was functioning?
Do you have a FTA satellite receiver to verify that the dish, LNBF, motor, cables, fitting are working?
The Starbox does not have a very strong tuner, so the quality levels may be low. It would be advised that the dish and motor be installed with a standard receiver, then switched over to the much more complex computer based receiver.
